Thread: A really dumb question - crankshaft pulley
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    OK, laugh at me if you will . . .
    If I remove the starting dog, and pull the crankshaft pulley out, will the engine oil come gushing out or is there another seal around the crankshaft which will hold it in?
    In other words, do I need to drain the engine oil before removing the crankshaft pulley?
    Thanks, Peter
    Crafers West South Australia
    Quote Originally Posted by peterg1001 View Post
    Thanks, Peter
    No, the crankshaft does NOT run submerged in oil, that is why your sump has a section below the crank area to hold the oil. Use your dip stick to gauge the oil height and you will see.
    Near Seven Hills, Sydney
    That ^^ and there is a seal called a crank main seal or thereabouts thats meant to stop the oil pouring out. Mine weeps. Damned dog is too hard to remove so it can keep weeping.
    Feb 2009
    Quote Originally Posted by isuzutoo-eh View Post
    I put a big adjustable spanner on the dog, rested the end of the spanner on the passenger side chassis, made sure the ignition was off and turned the engine over.
    No problems.
    Peter
    Narrogin WA
    There isn't a main seal on the front of the crankshaft, instead the seal in the timing cover does the job,
    Cheers Charlie
    Oct 2010
    Yarra Valley Victoria
    There is no such thing as a dumb question
    JDNSW's Avatar
    To summarise the answers above - The crankshaft is above the oil level, so you won't get a lot of oil out when you remove the pulley (but you will get some, as there will almost certainly be a little in the bottom of the timing case).
