Results 1 to 10 of 15
Thread: Introducing Louise
    Barwite. Victoria
    Introducing Louise
    I have been having withdrawls after selling my last LR and I stumbled accross this 2A on Ebay down the road from me.
    The radiator is in need of an internal clean, a slight miss in number 6 cylinder and requires a general tidy up.
    Uploaded with ImageShack.us
    It is a 6 cylinder with a generator instead of an alternator
    I have stripped the old timbers off the tray and will start the cleanup for the roadworthy.
    So if you are in the Mansfield area and see this, give a wave
    May 2008
    Bundaberg Qld
    Looks great Gavin. A couple of question though . What motor does it have in it as the 6 cyl Landy motors where a late 2A thing and yours has narrow headlights (early).
    And why is it chained to a Hilux ??
    Oct 2010
    Yarra Valley Victoria
    Congratulations Louise looks fantastic
    All you have to do is get rid of the Hilux now (great cars but they have no personality)
    Keep the photos coming
    How strange I hve not seen you in I dont know how long I mention your name probably 1/2weeks ago and you appear
    And you have a 2a in the same colour mine is going to be painted AND you called it after me
    Spooky
    JDNSW's Avatar
    Got any pictures under the bonnet and in the cab? The six started in 1967, and the headlights went into the mudguards in 1969 (although some may have been later - my 1970 model has them in the radiator support), so this looks like a fairly early, possibly very early six, and hence may be significant.
    Barwite. Victoria
    Spooky
    Thanks Louise, I know it would of been good things said about me..
    John the number on the plate inside the cab is 34703636D
    Could you please interpret it for me
    What is the hole beside the temp gauge for....there isn't any holes been drilled in it at all,,,not even for a radio or CB/UHF
    Oh the pleasure of driving around heaterless
    The head came off today and there was oil leaking thru to number 6. I will clean up the valves while it's off
    Waiting on gaskets, thermostat cover and the radiator wired out
    JDNSW's Avatar
    According to the parts book, the hole next to the temperature gauge is for "Plug Large, For redundant holes in panel, 338016".
    Narrogin WA
    Nice car! It must be quite a rarity nowadays to find one with the original six-cylinder engine.
    JDNSW's Avatar
    Quote Originally Posted by chazza View Post
    There is an article on this engine in the LRO magazine I picked up in town today. As they point out there, it was not a lot more powerful than the four anyway, but then because they needed to sell it into markets with low grade petrol, it had to be modified to low compression, add emissions modifications, and the extra power was just about enough to carry the extra weight. The Westlake conversion fitted to the NAS models was notably better, but as pointed out, this is incompatible with RHD.
    One point I would disagree with about the article - they refer to the engine as being a "1930s design". Hardly accurate - the patent for the IOE design with hemispherical combustion chamber was issued in September 1942, and the six was not even on the drawing board until the early fifties. Just for comparison, when the engine was introduced in the Landrover in 1967, Toyota was using and engine design in the Landcruiser first introduced by Chevrolet in 1929 (and based on a 1914 engine), and the CJ Jeeps still had the prewar side valve engine, although this was modified about then to an IOE configuration.
    Despite having little to recommend it as far as power or economy goes, the six is a very nice engine to drive in good condition, but seems not to stand abuse as well as does the four. And parts are a lot harder to find.
    Oct 2010
    That's nice!!
    I am impressed! That's a very nice looking Landy you have there Gavin. Can't wait to see more of it as you tidy it up a little.
    Thanks for sharing.
    John B
