28th June 2011, 01:06 PM
Disco 300TDi electrics all dead.
Just had to replace battery in my 98 disco, so I took the opportunity to tidy up some of the wiring and replace some dodgy terminal connectors. Upon reconnecting up the battery everything is dead. Nothing works. I have checked all fuses etc and nothing untoward found. No ignition, no lighting etc. What have I missed or more importantly what have I stuffed?
Any help would be appreciated as electrics are my downfall.
Chiseller
28th June 2011, 04:32 PM
Check all of your earths first, Regards Frank.
30th June 2011, 08:42 AM
There is a cable between battery positive terminal and the main fusebox. It has a fusible section. You can check it too.
30th June 2011, 09:14 AM
#4
i would say that you have forgottern to reconnect something, as it all worked before you pulled it apart.
30th June 2011, 06:00 PM
#5
Battery in the right way around?
Stranger things have happened....
Pete
Dizzie, 08 D3 TDV6 SE
