Results 1 to 10 of 12
Thread: UHF VHF Radio 50Watt
    Mar 2011
    Hey Everyone,
    Found a cool little unit whilst browsing Alibaba.
    Cheap Vehicle radio Yaesu FT-7800R products, buy Cheap Vehicle radio Yaesu FT-7800R products from alibaba.com
    $200 gets you a highly illegal 50Watt VHF - UHF Yaesu unit from China. Seems like a kinda cool thing to have, selectable output powers.
    Alex
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by alexturner View Post
    <snip>
    Alex
    Alex
    And if I saw you with it I'd be reporting you to ACMA imediately!
    Amateur radio ops spend a lot of time studying and sitting exams to be able to use these sets.
    Diana vk2fvrc
    Aug 2008
    Naivety showing here, but why is the unit illegal?
    Are you only allowed up to a certain power?
    Jan 2011
    Kialla, Victoria
    Alex
    Diana vk2fvrc
    +1 to that VK3HKH
    Jan 2011
    Kialla, Victoria
    Hey Everyone,
    Alex
    PS UHF CB is on 477Mhz so these sets no good for CB users.
    1.20 MB
    Quote Originally Posted by nice1guv View Post
    The citizen band only allows up to 5 Watts of power on certain frequencies.
    Outside those parameters you require a licence of some sort. It may be a commercial licence on a fixed frequency, usually 25 watts for VHF, marine licences go to hundreds of watts, or it may be broadcast licence allowing power up to (and sometimes beyond) a Kilowatt.
    The set advertised here is actually amateur radio equipment and is legal in the hands of a licenced amateur radio operator.
    May 2011
    Yep, what Diana said.
    Thanks for that btw.
    I will however also put a slight rider on that.
    The unit is still illegal even in the hands of an amateur radio operator if it is operated out of license. That is, operated on frequencies not allocated for purpose, at a higher output than allowed, or even transmission type.
    As another aside. Some of those programmable chinese built units which have been set up to operate on the UHF CB frequencies are also illegal if they can be altered to transmit out of band by a non-licensed user (which the non-amateur radio licensed G.Public is).
    Caveat Emptor. You have been warned. ACMA have no sense humour when it comes to operation of equipment like that. Come to think of it neither do the ARO's who have worked hard for their licenses.
    OK, I'm calm now, soapbox packed up.
    Iain (VK3YJH earlier in life)
    Iain
    VK3BIT
    03MY Range Rover HSE Td6
    Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
    LROCV DTU member
    Melb. Vic.
    Hi alexturner,
    Why not sit for the new amateur license , it’s pretty easy and you can use it legally (although still only 5W on CB Bands.)
    The reason why we hams get a little defensive is that with a unit like you mention you can very easily cause interference which we get blamed for.
    "It must be that guy down the road with all those antennas".
    And offcourse power is not linear, so 50 watts does not mean you get 10 times further. And if you did you can’t hear the other guy because he's only got 5 watts.
    My advice is get the biggest gain antenna you can afford/fit and a 5watt radio will operate beautifully.
    Also check out The Wireless Institute of Australia
    Ham radio is fun but we get a little defensive of those abusing our hard fought privilege.
    Paul
    VK3GPS
    1.20 MB
    I pay homage to those full call and standard ops out there.
    The electronic theory of the higher licences scares me and my fading brain a lot.
    Must get to the books!
    Diana
    Melb. Vic.
    Diana
    I did it when I was younger and had more brain space! 10wpm cw was the hard bit! Thank goodness we don't have to do that now.
