Check the two philips head screws holding the main body to the throttle body, they often come loose after adding a gas adaptor. Doing your overnight soak on petrol is the worst thing you can do for the carby, cyclic drying out of used gaskets is the quickest way to weaken them. Purchase a carby gasket kit, install it, and start it on gas in the mornings. Keep the petrol for the open road.
