Results 1 to 10 of 18
Thread: New PC System?
    Treads Guest
    New PC System?
    Hi
    It's been about 5 years since I upgraded my desktop and with a decent tax cheque on it's way I reckon it's about time I did
    I've bought a couple of Gamer type systems through GameDude in the past; but thought I'd shop around this time since I haven't kept up to date with the industry. I am quite capable of building my own if I'm given the right specs - so that is also an option. I'll keep my 24" LCD and keyboard/mouse etc. I really only need the main box and will be spending up to $1500ish.
    So can anyone recommend a good company to go through for either a pre-built system or to buy all the bits through? I'm looking for something with up-to-date graphics and a decent sized mix of CPU power, memory and HDD capacity.
    Cheers!
    I find UMart have the best overall prices although you can do better by buying each component from separate shops.
    Don't do what I did and put a hi spec processor in a small box. I used an Antec NSK1380 cube which, while the foot print in nice and small, there's not enough room for a decent fan and insufficient vents.
    Feb 2009
    Rutherford AKA Maitland NSW
    Here is what I am building in the next few weeks
    Antec Dark Fleet DF-30 Case $115.00 Intel Core i5 2500 $205.00
    Corsair Vengeance CMZ8GX3M2A1600C8 8GB (2x4G DDR3 $125.00
    ASUS P8P67-M PRO Motherboard B3 $159.00
    Corsair AX750 Gold Power Supply $219.00
    Lite-On IHAS324 24x DVDRW $29.00
    Gigabyte GeForce GTX 560 Ti Overclocked 1GB $249.00
    OCZ Vertex 2 3.5in 120GB SSD $199.00
    Western Digital Caviar Blue 1TB WD10EALX $59.00
    Sub-Total: $1359.00
    Add $109 for Win7 Home premium 64bit
    This is going to be a gaming PC for BF3 if your not into gaming drop the SSD drive and you could get a lesser Motherboard as this is a Crossfire/SLI board and save about $250
    I am going to chuck a second GTX560 in when BF3 comes out in Oct.
    All from PCCasegear with about 40-60 delivery
    Dazza
    Last edited by Dazza67; 10th July 2011 at 08:09 AM. Reason: Wrong month for BF3 due date 25 Oct 11
    May 2003
    On The Road
    I'm sure our own Incisor would build you a nice one,,,
    oh,,
    and Dazza,,
    I hope you have better luck with your 560Ti OC
    My SOC failed and they couldnt/wouldnt replace it,,
    ended up with a 570GtiHDOC with the store credit,,
    Treads Guest
    Thanks a lot Dazza
    That looks similar to what I'm after (performance and price ). One thing I found in the past was that some motherboards etc weren't stable with certain types of memory or graphics cards. Is this still the case, or should I look into which combination to get?
    Just to clarify:
    Back in the day I built a system based around an MSI motherboard with AMD CPU, Nvidia graphics card, etc. I got heaps of errors and shutdowns straight away and after swapping out components I found that it was the GC that was causing it. I then searched around on the net and found that it was a common problem
    Re hardware compatablity - In the past I have never had a single problem with ASUS or Gigabyte motherboards built around Intel chips sets, would not consider anything else. Just my opinion.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Sep 2010
    Moe, Victoria
    You might find this link helpful
    South East Tasmania
    Quote Originally Posted by Ferret View Post
    What about going full Intel system? If it is built by an authorized dealer it used to have a very good backup
    Garfield, Victoria
    Quote Originally Posted by Treads View Post
    Hi
    Cheers!
    Whatever you do, get an SSD drive to install Windows and the programs, then use a separate drive for data. I have just upgraded my machine to use an SSD, and it is the single best thing you can do for your computer, IMHO.
    Lionel
    Adelaide SA
    Ummm - can I ask what a SSD drive is?
    Never heard of one, but think I might need one... dunno why, but I just might..
