Results 1 to 6 of 6
Thread: converting to gas
    Sep 2010
    rothwell
    converting to gas
    Hi all, Thinking of converting my 93 3.5 V8 Disco over to gas and the small petrol tank. Any reccomendations of who would be the best in Brisbane or the Sunshine Coast to do the job and what system would work well. Also what oil, plugs, leads, and timing settings would be the best to use. Many thanks, Bob
    Crafers West South Australia
    I suspect your answers will be found many times over in the LPG section.
    Every workshop which quotes you for a conversion will have a different preferred system. My favourite system is collected from various sources and is not available from a single supplier. It allows both for maximum economy and power as it used an exhaust sensor driven LPG fuel processor. Hardly any other lpg fitter will do this as they are not required by law on the D1.
    My 5cents worth: Impco is rubbish. Too great a loss of low down power.
    NSW Far South Coast
    Listen to Bee Utey!
    I've just redone my P38 to a Bee Utey system and its definetly sooo much better than the Impco system that was on it.
    You can't deal with anyone who knows more about gas on Rangies, and he is so helpfull.
    Sep 2010
    rothwell
    Thanks Bee Utey, Any hints on what parts are the best and would a seqential system be the best? Also, what plugs are the best and what oil would you reccommend? would a change of camshaft be a good idea?
    Thanks, Bob
    Quote Originally Posted by scruffy View Post
    Thanks, Bob
    Zavoli or OMVL converter
    42mm ID mixer
    GASTEC FP50-TOW processor, heated oxy sensor.
    Bosch WR7DC+ spark plugs, 0.7mm gap
    10 degrees BTDC timing at idle
    Penrite HPRGas oil
    EFI cam should be fine
    Sequential isn't optimum as it relies on the LR petrol ECU for its signals and your vehicle hasn't got O2 sensors enabled. Very expensive for little gain. A mixer system can read its own sensor, quite cheaply.
    Sep 2010
    rothwell
    Thanks very much. Just the info I need to make sure that I do not spend money needlessly. Bob
