Defender seats will fit, even in the same holes. You can even lift up the bases to access under the seats. Disco seats can be made to fit, but sit you very high, if you are tall you will be looking at the top frame of the windscreen and the bottoms don't lift off.
If you search this section, Series 3 and Technical Chatter there are a couple of threads on fitting seats to 2As or 3s.
Jeff
 Must have gold in vinyl or something. How they come up with that Ill never know. They are basically square blocks of foam with a few clips. Ill ask for a quote from the canvas bloke.  he makes swags, soft top covers for 4WDs and canopys for other things. See if he can beat $1200.
