                                                24th July 2011, 04:33 PM
			TD5  Cltuch problem HELP
					Vehicle Details
 2000 td5 defender
 disco transfer case
 255-85-16 tyres
 chipped
 larger intercoller
 here is the problem replaced the clutch and flywheel and rebuilt the gearbox, all going well till i put a chip in it now the clutch has started to slip in the last few weeks and especially when i put the intercooler in, have checke dfree play etc in clutch all okay so i removed the slave cylinder and took it for a run without the clutch no probs not slipping at all, so i removed that great big spring from the slave cylinder as this pushs  on the preasure plate quite hard this has helped a lot but i can still get it to slip when pulling hard in 3 and 4 gear
 any thoughts on the problem or does the clutch have to come out to check for faults
                                                25th July 2011, 12:05 AM
					Check the master cyl. settings.
 Allan
                                                25th July 2011, 05:24 AM
					Check the condition of the bore of both the slave and master cylinders
 I had a similar problem  and it turned to be the slave cylinder piston not returning straight away (because the slave cylinder was scored and leaking) which produced a clutch slippage problem after changing gears
                                                25th July 2011, 07:38 AM
                                                #4
			clutch
					master cylinder must be okay as i can push th slave cylinder all th way back in which means the master cylinder is returning far enough for the resevoir to be open and theres plenty of free play at the pedal
