The trailer wires should be spliced in on the RHS. There's actually a plug there for them. Should all be in parallel so if trailer light is out shouldn't effect tail light and vis-a-vie.
See if you can locate the wire at the front (fuse) end and test it there. From memory they all run inside the chassis rail to the rear.
