Results 1 to 10 of 13
Thread: Tire Size
    Apr 2011
    Victoria
    Tire Size
    I have searched and not found the conclusive answer I was looking for,
    I have some 15x8 rims that I am going to put some mud tires on I am looking at the BFG km2's but I can't decide between three sizes
    32X11.5R15
    33X10.5R15
    33X12.5R15
    I would like to get the biggest widest ones 33X12.5R15 but I am worried that I will ruin my turning circle and I will have to trim away bits of the body.
    From what I have read here the 32 are the closest to the standard defender size but the 33 will change the driveline ratio so that the engine revs slightly less at the same speed.
    So over to you, what size have you used and how have you found them on road and off? Were modifications necessary to fit them?
    Cairns, QLD
    Hi
    I'm running 255/85 r16s on mine which would be closest to the 33 x 10.5. I find that on the rear they rub mildly on the flares but they can be trimmed to be fine (this is on extreme up travel). I would imagine the 12.5 33s would have major issues.
    Josh
    Apr 2011
    Victoria
    Thanks for the response AKA, how does that size go for drivability?
    Cairns, QLD
    Post
    I run disco rims offset outwards by about an inch (just under i think) which actually gives me slightly better turning circle. Other than that on mine it gives the correct reading from the speedo (was always slightly on the optimistic side). My wife currently drives it as her daily driver so must be fairly good to drive
    If you are not planning any further modifications,then I would suggest selling the 15" rims and getting a set of 16x7's .This will then allow you to run 255/85/16 which is probably the tyre that best suits a Defender.16x7 also happens to be the size of series 1 Disco wheels,and you can pick these up fairly cheaply,and will give you the clearance you need.
    And my 35x12.5R16's fit easily with a bit of massaging!!!!
    Wayne
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    Feb 2009
    Quote Originally Posted by LowRanger View Post
    Wayne
    Wayne, do 255's on disco 1 rims remain inside the flairs?
    Onesilop, met a young guy running BFG km 33/12.5/15 on a leaf sprung Bundera last week. He said the tyres were great in the sand, but on the road aquaplained badly, tracked quite a bit, and very noisy.
    He said if he were to do it gain he'd run two sets.
    Jason
    2010 130 TDCi
    Apr 2011
    Victoria
    Wayne
    I am planning to "fix" the suspension the guy who had it before me fitted a bulbar and the front sags a little then I want to weigh it down some more with drawers and other stuff so once it is completed I will take it to get raised to normal height maybe an inch higher.
    What kind of massaging was required?
    Apr 2011
    Victoria
    Quote Originally Posted by newhue View Post
    I almost decided against the 12.5 inch width because I figured they are too far removed from the standard size.
    Yes 255/85/16's fitted to disco1 rims,fit nicely inside the standard flares on Defenders.If I was setting up a Defender for touring,this is what I would be using.
    And 15" wheels,depending on the rims,may have clearance problems,and 33/12.5/15 tyres have too much tyre wall and decrease stability in my opinion,much better off with 16".
    Wayne
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    Quote Originally Posted by onesilop View Post
    Standard height is OK. 1-2" lift will give a little more clearance,but you will need to look at shocks as well as springs or you can change mounts.There are many options.
    Just a little 2" lift,wider flares and a bit of manipulating of the body panels around the wheel arches.And then you look at all the mechanical things that need to be done
    Wayne
    Wayne
    ​VK2VRC
    LowRange 116.76:1
