Thread: 12V connection to GPS
    Williams West Aust
    I have an older handheld GPS that came with my boat.
    Its a Lowrance GlobalNav 212.
    The 12V cord is damaged and is no longer available in Australia,they are available ex USA via EBay.
    I have read the book of words,the unit runs on 5V to 16V.It automatically switches to external power if it is greater than the batteries(4 x 1.5V AA).
    Can I connect 12V power thru the AA battery compartment without causing damage via over voltage???
    I have tried fixing the power plug,not possible,its not a generic plug either.
    Probably better off just buying a USA based cable.
    LOWRANCE CA-2 CIGARETTE LIGHTER POWER CABLE 99-11 NEW | eBay
    Ideas thanks.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jun 2010
    Fremantle
    I don't think it would be a good idea to put 12 volts to the battery terminals. But you could get one of those adapters that fit into cigarette lighter and have multi voltage outputs.
    03 Disco 2a, TD5, Olso blue, 7 seater, Auto, Chipped, EGR'd, 2"lift, SLS, Dual Batteries, Provent, TM-2 engine saver
    Jun 2010
    Fremantle
    Is the end that goes into the GPS ok?
    could you cut the cable and put a new end on it?
    will have 5 or 6 wires,
    Red 12volt +
    Black 12 volt -
    Green
    Brown
    White
    maybe a yellow and or a shield.
    Just isolate all the unused wires except the red and black
    Perth, WA
    I wouldn't connect anything to the battery terminals - there's a good chance the voltage regulation is done either elsewhere on the board between the external power input and the other circutry, or in the cable itself.
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Williams West Aust
    Quote Originally Posted by dswatts View Post
    Red 12volt +
    Black 12 volt -
    Green
    Brown
    White
    Its the plug that joins to the GPS thats stuffed.Was suggested that I open it up and fit my own 12V input.
    My boy has a PayPal account,will get him to buy me a new cable ex USA.Cant afford a new GPS at the moment,so I dont really want to stuff this one up.
    Andrew
