                                                8th August 2011, 09:11 PM
			Additional Scangauge2 Xgauge codes for Pumas
					A duplicate of a post I did on another forum for scangauge 2 owners with Pumas:
 Some  Xgauge codes that work on Defender Pumas.
 New XGauge: Fuel Pressure (if no FPR, Fuel Pressure at Rail).
 TXD: 07E00123.
 RXF: 044105230000.
 RXD: 2810
 MTH: 000100570000.
 New Xgauge display name: FPr.
 Measurement units: PSI.
 New XGauge: EGR Duty Cycle
 TXD: 07E022113C
 RXF: 04628511063C
 RXD: 3010
 MTH: 03E87FFF0000
 New XGauge display name: EGR
 Measurement: Percent %
 New XGauge: Cylinder Head Temperature (Not coolant temp at head)
 TXD: 07E0221624
 RXF: 046205160624
 RXD: 3010
 MTH: 000200010000
 New XGauge Display Name: CHT
 Measurement: Degrees Fahrenheit
 New XGauge: Fuel Pump Duty Cycle
 TXD; 07E0221672
 RXF: 046205160672
 RXD: 3008
 MTH:  006400800000
 New XGauge Display Name: FP
 New XGauge: Fuel Level
 TXD: 07E02216C1
 RXF: 0462451606C1
 RXD: 3010
 MTH: 000101480000
 New XGauge Display Name: FLV
 New XGauge: Horsepower
 TXD: 00
 RXF: 400080000000
 RXD: 0000
 MTH: 000A00240000
 New XGauge Display Name: HPR
 Measurement: Diesel Gross/Brake
 New XGauge: Engine Run Time
 TXD: 07DF011F
 RXF:  0441051F0000
 RXD:	2810
 MTH: 0001003C0000
 New XGauge Display Name: ERT
 Measurement: Minutes
 If I find more that work on the Puma I'll add them here. If you have any that work on the Puma then please add them to the list
                                                10th August 2011, 07:28 PM
					A quick update to the post.
 On the EGR gauge the screen reading is in percent. 0.0% means the EGR is fully closed. 100% means EGR is fully open and should only show 100% when accelerating and at engine shut down to show the self clean cycle.
 Fuel rail pressure gauge reads MPa, The Puma Duratorq engines fuel pressure is a maximum of 1600 BAR which is 23,206 PSI. Also the readings are Historic (milliseconds) and do not refresh quickly enough to give a 100% pressure reading at any one point in time and so should be used as an approximation of Fuel rail pressure.
                                                19th August 2011, 09:58 PM
					Thanks heaps for those codes, they work a treat. Is it possible to make the CHT read Celsius rather than Fahrenheit?
 Craig
                                                19th August 2011, 10:06 PM
                                                #4
					Hi Craig,
 not sure as I haven't tried.
 Also please note that after some testing of the EGR gauge using the scangauge, nanocom evo and the MSV that the 100% reading on acceleration is not accurate. The EGR will close completely at full pedal to the floor acceleration and the xgauge shows this as being open 100% which is false as it should show 0%. Also on normal acceleration the gauge shows 100% which again is not correct as the msv shows up to 90% through the TPS with gradual acceleration. I will have a play about with the sensor addresses to see if this can be resolved. But on a positive note all the readings not showing 100% are accurate.
                                                21st October 2014, 07:49 AM
                                                #5
					CHT in Celcius?
 Anyone?????
