Results 1 to 10 of 18
Thread: Great disappointment with a new Nanocom Evo
    Aug 2009
    South Africa
    After following all the in and outs of Electronic Diagnostics, I eventually decided on buying a Nanacom Evo. I was also put on a waiting list for nearly 3 months, and when I was told that the new model was available for sale I ok'ed the bank transaction.
    I was given a DHL tracking number, and after a few days it had arrived in Jo'burg SA. After another few days I was contacted to pay the Vat & Customs, which I did. I then had to wait nearly a week before it was eventually delivered to our small rural town.
    Great was the excitement today (Sat), after I had organized my son who has a PC Bussiness, to help me set it up. Everything went well with the codes ,setup etc, and we took it on a test run. Every now and again the Evo would " loose contact" with the OBDII plug, and my son would Reset it. After 4 different runs we came home and plugged it in to the PC. When went through the data and decided to do another run.
    When we plugged it into the Defender 99 Td5 the Evo would not power up.We tried it with my other 05 Td5, but once again .... blank screen. We tried it again with the PC and again ...all Blank.
    HAS ANY OTHER MEMBER HAD THIS PROBLEM WITH THEIR EVO'S? and if so .... how was this problem rectified?
    I have contacted BBS, and hopefully they will contact me on Monday.
    Dec 2008
    Yelling about things isn't going to make support happen any quicker and only serves to irritate those who might be able to help.
    Now having said that, since you have managed to sort out the unlock codes successfully the Evo must have been working properly when you received it.
    Can you please describe what happens when you;
    ==> Connect the Evo2 to the vehicle ODBII socket
    ==> Connect the Evo to a Windows XP (or later) machine using the USB port
    ==> Connect *Just* the external plug pack power supply (Not sure if the Evo2 has an external power socket ? )
    *** Make SURE you have correct polarity and voltage BEFORE you connect the power supply ***
    You could have a problem with the ODBII socket in the vehicle - mine has very weak contacts and tends to let go of the Evo's cable.
    There could be a problem with the cable itself, maybe a broken solder joint in the connector ?
    There could be an internal problem with the Evo, but since it worked to start with, I think this last option is unlikely.
    Is there anybody local to you with an Evo ? Trying a known good cable would certainly help narrow things down.
    Pete
    Jul 2011
    Scotland
    What colour is the OBDII Plug? Blue or Green? or have BBS changed the plugs since Mattia's time?
    Green plug was wired for TD5's only and the Blue plug did both Puma and TD5. If you let me know what the vehicle is I will check what the live pin is so you can put a DMM on it to see it's not a power issue at the vehicle OBDII end. Also you could do a continuity check on the OBDII cable and plugs to rule that out as a cause.
    Aug 2009
    South Africa
    Thumbs up Thanks for the reply.
    Pete,
    Sorry if I came through as yelling. My big concern is that I have to send it back to Cypress. The easy part was getting the unit here to South Africa, but sending it back and the expense invovled is another matter.
    One would just think that because the units are shipped from Cypress (very limited market) every care would be taken to make sure that the units and all the connecting cables are working properley.The instructions sent with the unit is very limited, and not much more on the BBS web site.
    Quote Originally Posted by peter5111 View Post
    When first connected all the diaognestic functions performed as meant to.
    When the codes were entered and the unit unlocked everything functioned as mentioned in the instructions.
    We did that again after seeing that the unit would not power up from the OBDII port.
    Yes the Evo II has an external power socket, and one is told that the usb port does not supply power.
    Yes, the polarity and voltage was checked before connecting
    Like I said in my write up the plug seems to loose contact, and that my son saved the data up to that point, and then opened another file.
    Also when we found that the unit didn't power up in the 99 td5 we tried it in the 2005 td5 OBDII port.
    Maybe, but the unit woldn't even power up from the mains to 12v transformer lead.
    Very possible, unless there is a reset switch somewhere.
    The upsetting part is the closest possible known units are 300kms away.
    This the main reason I bought the Nanocom is to be ale to do the diagnostics and the repairs in the "sticks"
    My son will though be able to check and if neccesary build up another cable.
    I must add, one of the main reasons I bought the EVO is that I am very impressed in the way BBS GUY on the forum seems to follow up on the chat and keeps giving us members feedback.
    I am sure that we will be hearing from him soon.
    Thanks Pete,
    regards,
    farmergeo
    Aug 2009
    South Africa
    Lorryman,
    Quote Originally Posted by Lorryman100 View Post
    The OBDII plug is blue, and we tried it on a 99 and 05 td5. I will get my son to do a continuity check in the meantime on all the cables.
    Thank you,
    farmergeo
    Jul 2011
    Scotland
    Quote Originally Posted by farmergeo
    I do believe that BBS test everything that gets shipped including accessories before shipping. I recently got a MSV2 and the check sheet was attached to the inside of the MSV box and was assembled by one person and checked by another.
    Sep 2009
    Limassol, Cyprus
    Hiya all. Sorry to hear your woes Farmergeo, I understand you must be upset and frustrated, probably more so than if it did not work from the start, as then you would not know what a brilliant bit of kit it is and might not be so desperate to get it going again
    For what it is worth, everyone had to wait to get their hands on these, some for much longer, and no one knew just what a nice job we were doing and that the wait would be so worth it.
    It was only the fact that you were on the list at all that saw you able to get one so quickly and in fact today is the first day we can ship to customers not on the list although i know this won't be the case for more than a few days.
    I guess that given the truly vast amount of these we have shipped in just a couple of weeks, and how quickly we tried to get them available again, there was bound to be the odd problem.
    It's only a shame that hardly anyone ever writes in or posts up to say how pleased they are, worth the wait, nice job, or to say that they had no problems, But we sure do get to hear about it when someone does have a problem
    Although it was unfortunate enough that this happened on a Saturday when we would normally be closed for 2 days anyway, you also had an additional days delay in getting an answer from BBS which was caused by the fact it was a Bank holiday here yesterday. Even although i was very hard at work elsewhere.
    Your apparent assumption that we do not already take every possible care regardless of our, or a customers, geographic location is absolutely not the case. Everything we ship is tested multiple times before dispatch.
    Co incidentally I do not think that there was anything physically wrong with your unit and certainly it is very unlikely that you have a lead or connection problem.
    I am fairly certain that your only problem would have been occasional communication disconnections and from the TD5 Engine Management while the engine is running causing freezing up or dropping out of live data collection. This is because we have had a growing number of reports of some customers, now totally almost a dozen, who have experienced this communications problem. Naturally we have not seen this before and it has not happened during the testing we have done on vehicles and percentage wise it's looking like only about 1 in 20 are experiencing this problem. This can apparently also be caused by bad earths.
    However late last week we managed to see and test the problem ourselves and get to the bottom of it. It looks like a global improvement we have made to speed things up in the newest software revision, has got so borderline with some versions of the TD5 ECU and / or it's Software, that the TD5 ECU occasionally fails to respond to a request for live data when the engine is running. Sadly in a few cases, folks who think it's their Vehicle, their Nanocom unit, their OBD connection or otherwise have tried all manner of things, which sadly can under just the wrong circumstances can corrupt the units firmware flash drive or have other un desired effects.
    We have already made changes to solve this TD5 ECU with engine running problem as well as making the firmware flash drive write protected at all times, except during updating etc and even improved the restore function for the drive significantly as some have had problems doing this.
    This is currently being Beta tested, so we really are on the case with this and doing the best we can to resolve it as quickly as possible.
    I know my support team are now communicating with you to see if your unit can be fixed remotely or if it will unfortunately need to come back.
    In the meantime might i add my appreciation and thanks to the many members providing help, support and advice.
    I would also like to point out that all guides, information and literature is available from The Nanocom.it site
    Colin
    MD of Blackbox Solutions Ltd.
    www.blackbox-solutions.com
    Aug 2009
    South Africa
    Thumbs up
    BBS GUY,
    Quote Originally Posted by BBS Guy View Post
    .............I know my support team are now communicating with you to see if your unit can be fixed remotely or if it will unfortunately need to come back.
    You are correct, emails are going back and forth from the support team and it seems that the problem is being narrowed down.
    Like I said in a previous post on this topic,
    .........one of the main reasons I bought the EVO is that I am very impressed in the way BBS GUY on the forum seems to follow up on the chat and keeps giving us members feedback.
    Thank you Colin,
    farmergeo
    Jan 2008
    Gladstone, Queensland
    BBS Guy,
    I too recently recieved my Nanocom Evo and have also suffered the loss of connection problems, but thanks to your very informative post, no longer need to spend the coming weekend trying to find an imaginary loose connection!
    Meanwhile, I shall wait patiently for the software upgrade. Please don't take too long as first impressions of the unit are good, with a clear easy to read screen and easy to use menu system.
    Can you post a notification on the forum when the upgrade is available please.
    Regards,
    Ray
    Northern Tasmania
    BBS Guy
    I've also had the above problem but only on long trips which I thought was just a connection issue.
    I've also just found that I have the old oil in injector loom problem. I only suspected there maybe an issue as the nanocom battery voltage was jumping around.
    I've ordered the parts and it will be interesting to see if it solves the Nanocom issue. I'm not though planning any 1 hour plus trips required to test the result.
