I am not Tim, but I would use a 3 position toggle switch (ON-OFF-ON) - one side, the spotlights turn on and off with the HB, the other side you turn them on. I will draw a diagram so that is clearer.
EDIT - diagram added. I am not familiar with Tim's kit, however by the sound of it you would just need to swap the standard toggle switch for an on-off-on type, and run the additional wire from the battery to the toggle switch.
In my diagram, if you flick the switch down, the spot lights will turn on and off with high beam, if you flick it up, they will be constantly on, and in the middle will be off.
