I have polyair and no problems I wouldn't do without them now.
Iain
Gday
Just made a decision to keep the lift in
But I'm still interested to hear from those of you with helper airbags fitted into 110s
What problems have you had? What brand Firestone or Polyair?
Iain
Me too but most of the time they run at 5 psi. ( until I put the camper on and load the back of the car up) then I run at about 12 psi. Best $ 400.00 spent
SYMOMe too but most of the time they run at 5 psi. ( until I put the camper on and load the back of the car up) then I run at about 12 psi. Best $ 400.00 spent
what type of springs do you have ie normal, heavy duty, raised etc
Thanks simon
Hi Jock
You probably remember me showing you my white wall Cooper ST-C !
http://www.aulro.com/afvb/attachment...0&d=1313669613
I do like the ride of my bus now that, I have the Airman bags and tough dog foam cells in.
But when in some real twisty places, the springs can dislocate and not return properly, hence the rubbing of the spring on the inside of the tyre.
The fitting and using of dislocation cones to reseat the spring, isn't an option, as that,s were the airbag resides.
What to do? I am going to try an old seat belt, by going around one of the coils near the top of the spring then passing the two ends through to, between the chassis and the top of the bump stop.
Cheers Arthur
I've fitted Firestone bags to mine and could not be more pleased. On the last trip to the Kimberleys with the boat and all the gear, the headlights were in the tree tops, this with after market springs. Best thing I've done so far is fit airbags to this vehicle for touring. In town empty I run 5lb psi and as I have a draw system rack ect it rides well.
Allan
Polyairs fitted to 2" lift Kings springs. Makes a difference. Buy Aussie, go Polyairs.
2011 Discovery 4 TDV6
2009 DRZ400E Suzuki
2003 WK Holden Statesman
Departed
98 Ducati 900SS Gone & Missed
Facta Non Verba
2009 DRZ400E Suzuki
Departed
Facta Non Verba
