Results 1 to 10 of 17
Thread: FM Transmitter
    Feb 2009
    FM Transmitter
    I would like to connect my UHF radio to an FM Transmitter (via the external speaker socket) so that I can hear the radio communications via the speakers in my Defender (after tuning in to the appropriate FM broadcast frequency). Has any one done this? Indeed, is it possible? Any recommendations?
    KarlB
    Karl - why not just plug in a cable to the external speaker socket from your UHF to the Aux in socket on your radio - or doesn't a Puma radio have that function?
    Feb 2009
    The AUX socket in my Puma radio is blanked out. I think this is standard in Au Pumas.
    KarlB
    Canberra, Australia
    Karl,
    Sounds like you need a new radio!, both sorts! Currently collecting 80 channel interest.
    I like GCs call re using the Aux in, but may need the UHF feed to be from somewhere within the UHF rather than the speaker line. Also, pull the face off the existing radio and see why the Aux is blanked off.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Quote Originally Posted by KarlB View Post
    KarlB
    Ok - a friend plays his Ipod trough the radio via a FM transmitter and it works fine - his was about $60 off ebay.
    So I would plug this into your UHF ext speaker out socket (you will need to get Line voltages out vs Speaker voltages out to ensure compatibility) then tune in the radio.
    Melb. Vic.
    KarlB
    KarlB,
    As an alternative, I mounted a small ext speaker just behind my right ear and connected it to the CB.
    Something like this :
    That way you (and your pax) can still listen to music whilst you can also hear the CB.
    I also had a headset for offroad, so I wasn't fumbling for microphones.
    Feb 2009
    I should have provided a bit of explanation of why I want to do this. Some of you will know I have a significant hearing loss. I can hear the Defender radio quite well but have difficulty with the speakers in the usual UHF radios. I currently use a hand held and this is a pain while moving. I am about to buy a 'mounted unit' but because of my experience with hand helds, am not keen on a speaker/mic combo. An external aux speaker is certainly a consideration but this would really need to sit towards the front of me as hearing to the side and behind is not good. The FM transmitter option seemed simple with no extra wires poking around. And I know I can hear the 'in car 'radio without difficulty.
    KarlB
    Melb. Vic.
    Ahh that puts it in context KarlB,
    I would be looking to have it hard wired into the stereo, I have one of those FM do-dads for my ipod and they aren't great. From memory the Aus Puma's have the input in the front removed - no idea why - its a Land Rover thing. Would have cost all of $0.59.
    I am sure there'll be a way to get someone to wire it in - unless you are confident with a soldering iron.
    Apr 2010
    Emerald, Vic
    You could try mounting the UHF on the roof or in a roof console with the internal speaker facing down. This seems to work for me, although I have a Series 1 disco. I'll try and attach a photo.
    I have one of those FM transmitter gadgets I use in the 2a with an MP3 player. It should work - lead from the external speaker socket of the UHF to it.
