Results 1 to 4 of 4
Thread: RRS 3.0 suspension height fault warning
    Sep 2010
    Dunsborough
    Folks, I can't find any threads specifically relevant to this, so here goes:
    I'm getting an intermittent (but fairly frequent) warning on the dash that says "normal height only available" or similar. It happens (as far as I can tell) whenever I lower the suspension to access height, then drive off. The car automatically defaults to normal height, then the warning comes up.
    I'm going to call Barbagallo Land Rover's service department about this, but I want to be forearmed with any experience you guys might have before they give me a snow job and tell me to just switch the car off and back on again to re-set the software. I've done that many times and the problem persists.
    (Interestingly, the problem only started after a recent service in Broome after a trip up the Gibb River Rd)
    I await the advice of the gurus.
    Nov 2008
    Compressor valve kit...
    NSW SW Slopes
    Because its not just slow to raise, there will be 1 or more fault codes stored so the dealer should readily fix it.
    Sep 2010
    Dunsborough
    Oh thanks guys, that would do it....taking in for diagnostics on Thursday.
