no negatives until the axles snap at the welds.
then you're up for new axles and flanges, maybe stubs (since the damage will most likely be at the outer end of the stub) and bearings
essentially just the same as if you have a catastrophic failure of the axle at the start of the drive splines on the drive flange side of the axle.
					 ). I eventually went Maxi Drive.
