Thread: freelander gearbox removal
    basmar Guest
    Can aney one help with gera box removal tb4 it will not move is there aney must know hints please aney body
    keh?
    unbolt it and pull it out same as pretty much any other gearbox, did you miss the secret hidden bolts on/near the starter?
    basmar Guest
    Angry gearbox
    Quote Originally Posted by basmar View Post
    see above.
    the bit about the hidden bolt near the starter.
    every other landy IVe ever worked on has had at least one bolt thats been made hard to get to because the starter motor is either obscuring it, restricing access to it OR is held in by it but doesnt appear as though it should be at first glance.
    Hunter Valley
    there are 7 bolts that bolt the gear box to the engine. how many have you removed?
