Results 1 to 4 of 4
Thread: a few random questions...
    #1, when buying an O ring kit for the sediment bowl, should it come with just the 2 large O rings, or also the smaller one that is on the central post inside the top of the bowl mount?
    #2 what is the torque setting for the small bolts holding the cover plate on a LT230?
    NSW far north coast
    25 Nm
    (I did try and return your call, I was nibbling munchies and sipping wine at a 'Private Studio Viewing' when you rang and the phone was in the Patrol.
    Seriously. It was a busy day )
    where did you get the 25nm from?? cause most of the standard fastner tables are calc'd for being inserted into steel not aluminum...
    sounds like a good sunday mate, take it while you can. btw if you need a new battery give me a call
    NSW far north coast
    Straight out of the Gen-u-ine Workshop manual under 'Torque Values' 'Bottom cover to Transfer case'
