Results 1 to 10 of 21
Thread: Soldering tips
    Aug 2011
    Currently travelling with no fixed address. Previously, Cairns.
    Exclamation Soldering tips
    I tried to save some money and solder a new anderson plug onto my camper trailer today, and had no success. I bought a 40w iron, tinned the tip and then applied solder successfully to the 6mm auto-wire. But when I tried to heat the wire inside the anderson plug connector, I just couldn't get the solder to melt and make the bond.
    Was the iron I was using too small? Would a bigger iron have provided sufficient heat. Or is it all about technique?
    I'm trying to improve my non-existant skills so that I can make roadside repairs to my landy and trailer, as we're on the road for anothe 5 months.
    May 2009
    Tatura, Vic
    I reckon 40 watt is far too small. I would be using 80 watt for this.
    Dave.
    Jun 2010
    Bayswater, Western Australia
    Hi MarkandSandy,
    Yes 40w is way to small for that job, they are really designed for electronic circuit board work. I have a 120w iron that probably would have done the job without any real problems.
    You could (carefully) use a small gas torch to heat the pin (assuming that it is take out of the plastic plug first...)
    Ron
    Oct 2007
    wetherill park
    Yep 40 is a bit too small I use a gas torch to heat the tips and melt the solder then insert the tinned wire
    you're not supposed to solder anderson plugs, they're ment to be crimped.
    I agree, you are meant to crimp them
    If you are happen to be in melb with your travelling, I'm happy to crimp them for you
    Normanhurst, NSW
    Is there anything wrong with soldering a terminal that is designed to be crimped?
    I/ve been doing it for years on smaller terminals.
    Roger
    Crafers West South Australia
    Anderson plug connectors are silver plated, which is definitely not the correct plating for solder to stick to. A rotating head crimper isn't dear enough to worry about:
    6 - 50mm² Electrical Cable Crimper Rotate Crimping Tool | eBay
    Silver plating, on the contrary, is just about the best possible surface for soldering (except for gold), although in practice it may not behave any better than a clean tinned surface (and like any surface for soldering it needs to be clean). Historically the best quality plugs designed for soldering have had silver plated connectors, both the connecting and soldering parts.
    And some of us, perhaps less well off, would consider spending fifty dollars for a tool you might only use once to be something to worry about!
    Aug 2011
    Thanks All
    Sounds like in this case I can lay at least some blame on the tool then (and the rest on me for buying the wrong tool in the first place)! Looks like a gas torch/solder iron might be a useful additional the toolkit for repairs on the road when 240v isn't available.
