Results 1 to 8 of 8
Thread: TD5 - Check your oil filter
    Sydney, NSW
    Had a look round the engine bay today to try and track down an oil leak that started on the CSR and has been getting progressively worse.
    For some reason I checked to see if the oil filter was tight, it wasn't!
    It's a waiting game now to see if I get anymore leakage
    Jon
    Regards,
    Jon
    Funny thing is I had the same problem just a couple of weeks ago, I generally do it up as tight as I can as I just can't get my filter clamp to turn in such a tight area on the TD5.
    Also found out one of the rotor filter bolts has stripped from the main housing so now I have to get it helicoiled.
    Mildura,NW VIC
    Hi Jon ,
    I also had an oil leak around the filter area.My mechanic is a very experienced landy bloke and diagnosed on the 300TDI that an O ring in the filter assembly was the culprit.Seems this O ring is in the area that houses the oil cooler sensor or something.Showed me a very flat piece of what resembled a washer rather than O ring.
    New one is fitted together with4steering ball joints and new panhard bushes
    KGB is now rejuvenated
    Mary
    "Some people walk in the rain,others just get wet!" -Roger Miller
    SYDNEY -in the shire.....
    if you are using ryco filters.......they had a bad batch last year......
    they were not sealing properly at the crimp.....and hence leaking.......
    they have been rectified since........but if you get one of the old ones......
    Sydney, NSW
    Quote Originally Posted by DEFENDERZOOK View Post
    Thanks, always good to know these things. Mines a genuine LR one this time, normally a coopers!
    Regards,
    Jon
    never had any problems with coopers.......
    was the seal lubed prior to fitting the filter........?
    Nov 2008
    just watch,, seen them leak from been to tight aswell, i spin them on till seal touch, then just tighten about another 1/2 - 3/4 of a tern, only one had leak is when i didint tighten that way
    Sydney, NSW
    Not sure to be honest. I always do when I do my own servicing and have never had a problem. Last time though LR garage did it as I was under the pump with work before I went on my trip.
    J
    Regards,
    Jon
