The only differences are a longer (and hopefully stronger) chassis, heavier dual coil rear springs and heavier wheels. In addition, the "standard options" list is likely to be different. Obviously the body type will differ as well. The increased wheelbase means a larger turning circle, and the increased GVM (if you use it) means slower performance.
