Thread: LEDS in 110 Bullbar
    South Yundreup,WA.
    LEDS in 110 Bullbar
    For all those looking at replacement bullbar indicator/clearance lamps, I have just fitted a set of LED Autolamps 175mm. It took a bit of thinking but it is easy to do. Basically I used some 2" x 1" RHS tubing to make a backing spacer as the LEDs are way to thin. I also used 2 large washers on the back of each mounting point to push them out just that little bit further. Not a perfect fit but are ok, some minor gaps around, may look at filling in later.
    The only thing I dont like is the LED fascia only clips onto a backing plate. Would have prefered a screw fitting. If they do come loose I guess I can sikaflex or glue them in.
    Any way pics of the install.
    Installed and working
    Backing spacer front view
    Backing Spacer back view
    Spacer fitted to bar
    Plastic backing plate of light
    LED light I used
    And some Lucidity LEDs for the rear end.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Jul 2007
    Good job.
    I like the rear lights.
    South Yundreup,WA.
    Quote Originally Posted by slug_burner View Post
    Good job.
    They are Lucidity brand, I got them through Bretts Truck Parts.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    VladTepes's Avatar
    Bracken Ridge, Qld
    how much for the rear lamps ? Ho3w bright are the reversing lights?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    South Yundreup,WA.
    Quote Originally Posted by VladTepes View Post
    The rear lights were $143 ea (RRP of $296 ea). The reverse lights are probablly on par with the standard light maybe a bit brighter, have not really tried out at night yet.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Nera Donna Guest
    The front indicators really look the business. And the rears are very trick. I have had the exact same front ones on my wish list for a little while now. If you don't mine me asking, what was the damage on fronts?
    Good job and very slick.
    Craig
    South Yundreup,WA.
    Quote Originally Posted by Nera Donna View Post
    Craig
    I bought them on line, I think $47 ea or around that from Bretts Truck & Trailer Parts.
    They are a fairly generic item.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
