Thread: Trouble with trailer outlet?
    fender22 Guest
    Hi all. Have a 2007 FL2 with 2 factory fitted trailer outlets on the back.
    Firstly I was wondering why 2? One is white.
    Am having trouble though with the output. Getting a constant blinker signal on one terminal irrespective of left or right signal given? I checked fuses and the plug on my trailer is definitely right. Any ideas?
    Ringwood North, Melbourne.
    Does your trailer have LED lights?
    Rob
    fender22 Guest
    Nah, they're normal lights
    mikehzz Guest
    The white one is for UK only I was told. Sorry, can't help with the blinker problem.
    sanark Guest
    Thumbs up New to forum (sanark)
    Hi all
    been checking on forum for a while now, just joined, I have a Freelander 1
    looking to set it up moderately I have a HR towbar for rear recovery, looking to set up recovery points at front, also spare steel rims not sure what tyres to fit.
    sanark
    Quote Originally Posted by sanark View Post
    Hi all
    sanark
    Hi Sanark and welcome to the forum.
    This a thread on trailer sockets on the Freelander 2 - as you have a completely different topic on a different car you should really start you own dedicated thread in the Freelander section - http://www.aulro.com/afvb/freelander/
    See the new thread button near the top on the left.
    However,
    For the Freelander 1 I would use your rear tow bar with a recovery hitch in the receiver.
    Front recovery hooks are more problematic - basically on a standard vehicle it is not really possible to put any on - yes could be done with lots of work but there is no where strong enough to bolt them to. There is the standard tow hook that could be used for an easy tow recovery but definitely not for snatch or other heavy load recoveries.
    sanark Guest
    OOPS!!
    Thanks Gary
    I have been following your threads for a while appreciate your help
    I have found the new thread
    Sanark
    However,
