Thread: Charging Car and caravcan batteries
    Scarborough, QLD
    I have a Traxide battery isolator in the Defender, a deep cycle in the canopy and a deep cycle in the caravan.
    Where should I plug in the Ctek to charge all the batteries - at the Defender crankers or on one of the deep cycles?
    from memory its the primary crank battery you want to hook up to.
    Mar 2009
    Port Stephens N.S.W
    Put it on the starting battery ... when the charge voltage rises high enough at the starting battery, the Traxide isolator will connect the two other aux batteries, which will then also start charging.
    If you put it on either of the two aux' batteries, AND the Traxide isolator has isolated the aux' batteries from the cranking battery, then only the aux' batteries will be charged.
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    Logan Village area S.E. QLD
    Sorry no answer here....
    get the f... out of Bris and get on your way..........deal with it later
    see you @0600hrs
    Mrs hh
    hhmmmm bacon, eggs, snags, tomatoes, hash browns and toast on the camp fire
    Series Landy Rescue
    Our FB Page..
    Oct 2007
    wetherill park
    Wot she said a good drive to sydney should have them all fully charged
    But as dave said the cranking batt is the one for the reasons kev said
