I've gone and purchased myself a new work/play car
1992 LAND ROVER DEFENDER Cars For Sale in QLD - CarPoint Australia
It's a 200 Tdi 110 tray back ute.  I've loved the look of the utes for a long time now and had a couple looked at before I purchased this one.  I had a mechanic go over it, and other than a few little problems (to be expected of a car this age) all seems well.  It is currently on the back of a truck coming from Qld to Melbourne.
I've got a few little plans for it, but also have a few questions for the Defender gurus.  I'm planning a dual battery system, mud pod with new stereo and uhf, and a general tidy up.  Suspension I will give it a basic two inch lift, with 3degree castor corrected arms and cranked trailing arms. I'll be running 33inch all terrain tires as daily tires, and have a set of 35's I'll be using for 4 wheeling/camping weekends.
I have a front diff lock and upgraded cv's that I'll put in.  Now for the question.  The front diff is already built up and running 4.11 ratios.  The rear diff is completely standard at the moment. I'm planning on putting a Detroit in there though.   Would I better off changing the front ratios back to standard gearing, or changing the rear ratios to 4.11s?
If it was on a Disco I would keep with the 4.11s, but having heard the Defenders have the different ratios in the transfer case I don't know with way to go
