                                                25th September 2011, 06:17 PM
			door stay part number
					I believe on the 2 and 2A there was a door stay for the front doors, it may have been an accessory.
 It's a cylinder that is attached to the dash body, and has an arm that protrudes through the cylinder which in turn attaches to the door.  There is a rubber grommet inside it that stops the system bottoming out.
 I'm looking for the part number please, can anyone help me out?
 Jason
 2010 130 TDCi
                                                25th September 2011, 07:17 PM
					The rubber buffer is Pt No. 306471.
 The check strap is a standard fitment,
 Cheers Charlie
                                                26th September 2011, 04:54 PM
					Thanks Chazza, I used that part number hoping it would lead to the door check strap (cylinder) but no avail.
 would you have the part number of the actual door check,
 sorry for the hassle.
 Jason
 2010 130 TDCi
                                                26th September 2011, 06:22 PM
                                                #4
					If you mean the cylinder that is attached to the bulkhead they are handed; 330393 RH and 330394 LH. The rod for the check strap is 332715,
 Cheers Charlie
