Hi Dan,
I'm not an expert on either the Solex or the 2 litre (not an expert at all, really
) but in general a carbie's mixture screw only controls idle mixture. Above idle there is enough vacuum generated within the carbie to drive the normal circuits where the mixture is controlled by the jets and an accelerator pump of some kind that reacts when you first press the accelerator to give an extra burst of petrol. So given that the car is idling properly I don't think you need to play with mixture. Given experience with other engines then timing not being right can certainly cause backfires and poor running.
Are you setting the timing with a timing light or statically (lining things up then turning the dizzy until the points spark)? I would set the engine initially to the recommendations in the manual then you can advance it from there until you get pinging under load, then retard it just a little. If you are using a timing light you can rev the engine and make sure that it advances, you can also see if there is wear in the distributor by how solid the light is on the mark, if the mark is moving around around and is hard to tell if it is sitting in one spot then there may be wear in the distributor causing erratic timing. Also check that your leads are all good and have tight crimping onto the plugs and dizzy, points are clean and flat surfaces and that the plugs are set to the right gap and are also clean with no signs of arcing across to the insulator.
The process of setting timing is also a bit of a trial and error thing in that the timing varies with the revs and the revs vary with the timing so, once you set the idle revs and mixture, you then set the timing, that changes the revs so you then reset the revs and mixture, that changes the timing so you then reset the timing and so on until it all sits properly.
Hope that helps a little at least.
Tim.
Gumnut - 1953 Series I 80"
Poverty - 1958 Series I 88"
Arnie - 1975 710M Pinzgauer
