VDO Gauges would be fine.
Hey all , done a search but alas i suck
Are there aftermarket replacement gauges for fuel , temp on a 1997 Defender ..... the likes of VDO or Turboset ....
I am also looking into a Speedhut replacement speedo unit .
i tried a vdo gauge today as replacement for my fuel gauge and it worked in reverse ... so my tank is full and reads as empty ... the guy at the sop said Pommie cars are weird and they dont accept generic gauges ....
 TopicToaster
						TopicToaster
						A competent auto sparkie should be able to sort it for you. I'd hazard a guess that you need to switch the connections on the back of the meter. The trouble shooting info on the VDO electric gauges state that if you ground the wire that goes to the sender the fuel gauge should go to zero/empty.
You also need to ensure that you have a meter to match your sender with the correct ohm range.
i cant remem off hand but do a search on ohm range for defender, there is a vdo gauge that suits the factory sender resistance range.
Steve
E - F (240-33 Ohms) 2 1/16 Fuel $28.47
Part No: 301-105 Notes: For 240-33 Ohms sender, Auto Meter, SW. 12 Volts
hope this helps out anyone needing the correct VDO unit
I am after a replacement clock for a Defender TD5 as mine is running but running slowly , how reliable are these clocks? is it worth replacing the clock or would it be better to replace the clock with a rev counter or voltage gague. What have other people done re clocks in Defenders.
Thanks Allan
Hey Allan , i was put onto this site by the guys in the States who run 90's
so have a look they all swear by it scroll thru untill you find the clock for you
VDO: Vision Black Series Gauges: Fuel Level Gauges - eGauges.com
hth
aww... vision black ones are the matching ones...
i just ordered a vdo boost gauge last week and it was only a close match.
oh well
