Have a look at the TD5 in tank fuel assembly. The last time I had a look at a Disco one, once you remove the in tank pump itself, the only thing one would need for use (from my point of view being a 300tdi owner) in a diesel application was an extension tube attached to the stub where the pump would have attached. After all, that's what the 300tdi fuel pickup is.
