                                                9th October 2011, 10:15 PM
			Winch bar dimensions
					I went to fit a winch bar today but found the front of the passenger side chassis rail badly corroded
 I will have to get an engineering mob to cut out the damaged bit and weld in some new metal.
 I did however offer it up to get an idea of fit and function and to see if I could just move the fitting holes back along the chassis rail.
 With the top holes lined up and the underside sideways bolt  holes all lined up , it seems to sit way too far forward of the front of the guards.
 The winch will be a low mount type so maybe that's why it sits so far forward.
 Does anyone have a dimension from centre of top chassis mounting holes to back of winch bar plate where the winch would bolt on.
 Thanks Pete
