Originally Posted by
streetlander
Have been told (via another website) that its not economically viable to lift a Freelander.
Its possible and the parts are available
Bearmach BA 2225 Freelander 2 inch Lift Kit however general consensus is that it doesnt achieve much.
The ground clearance (or lack there of) makes it a futile exercise.
The engine skid plate, exhaust system and drivetrain (VCU etc) hang too low to do any extreme 4x4 which makes a lift kit pointless. Also alters the handling ie camber etc and will throw your speedo out
Not quite true - the FL1 has about the same ground clearance as a coil D3 and in all my offroad work I have not suffered damage underneath but I try to read the tracks and take the easiest line rather than taking the hardest line. Sure it will not do extreme tracks but then most standard 4wds will not either. (technical ground clearance of my FL1 is greater than the technical clearance of my 101 - measured under the diffs)
A spring lift will give you about 35mm lift and no issues. You can also go a spacer lift to give about 50mm lift - but might require some cutting of body work for the steering - a mix of spring and space can be done but is not recommended. The suspension is adjustable so can account for moderate lifts. Increasing tyre size also gives about 10mm - 15mm lift and does not put the speedo out - actually makes it correct.
A bash plate under the engine would be good and a smaller rear muffler would also be good.
