Results 1 to 8 of 8
Thread: how to check a HDD?
    May 2003
    On The Road
    how to check a HDD?
    My twin WD 500gb Black Caviars have been running in Raid 1 for a while now after its previous Raid 0 collapse.
    but the BSOD's have returned,,
    I have run chkdsk /R on one but nothing turned up-- (it does say something if it repairs files??)
    anything else I can try?
    it is on an XP machine atm---
    Jul 2009
    Mid North Coast, NSW
    287.34 MB
    May 2003
    On The Road
    well,,
    I ran the Data Lifeguard quick test,, which it passed,
    then ran the extended test,
    which it aborted after around an hour and a half,,
    does this test normally just abort if there is a problem?
    Are you running from Windows or boot disk? I'd run from boot disk just so other stuff doesn't get in the way.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    do you still have pc check?
    use the safe write bad sector test
    windows does not handle write bad sectors well at all.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2003
    On The Road
    I will search Inc,,
    both drives have now passed the extended check,,,,
    May 2003
    On The Road
    no to the pc check Inc,,,
    but ones run a hdd check and repair test off hirens (HDATZ 4.5.3)successfully and now its going through a write=read=write=compare test,, this last one might be finished by the time I come home from work----
