I was up in the city today.
Bought a new Ice Box for the boat.
Also bought a GME VHF/2.4m antenna/antenna base and radio patch lead.
Andrew
I like messing around modifying my toys.
This thread is for any modifications I do to my boat,Deckem.
Now I have used the boat a few times,I have a pretty good idea of how I want to fit a new VHF,stereo/speakers,the fire extinguisher,Epirb and store flares/emergency gear.
Currently the VHF is mounted where it does get spray on it with the bimini open,it failed on my maiden voyage.
I have no stereo,and there isnt much room to fit one in a protected area.
I asked my Bro,who is a cabinet maker to build to cupboard boxes,to go inside the bow area.The idea is to fit the VHF and stereo/speakers into the faces of the cupboards.One cupboard will be for emergency gear only,the flares,the Epirb on the inside of the door,mobile phones etc.It will be a fairly dry area,the other cupboard will be for keeping stuff dry for the trip,ie clothes etc.The remaining void behind the cupboards will be for the storage of lifejackets.
I will probably cover them in carpet.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Andrew
The cupboards look great! Cant wait to see them fitted!
What was the price of the esky?
They are $320,Fishwrecked members get a discount,I paid $297.Much stronger looking esky than many on the market.
Andrew
Bought some Everdure for the ply?
Tell me more Ben.
Im new to marine environments,I was going to put boat carpet on,Im guessing its a selant???
Worth using I guess???
Andrew
https://www.whitworths.com.au/main_l...rdure%20Primer
Primer and sealer for timber. 2-pack. All my boatie/yachtie mates swear by the stuff. You mix equal parts of the base and the activator. I just came in from everduring my deck - it took 1.5L each of base and activator to do the entire deck properly (2 thick coats wet on wet) - both sides - and especially the edges....
The everdure will make sure the timber does not get waterlogged.
I will be carpeting over the top.
Hi Ben
I spoke to my Bro last nite,he said the Evedure is very good,they use it on their marine jobs.
He also pointed out its overkill for where Im using the ply,suggested using a good quality spraying enamel 50% thinners mix for a few coats,then a couple of normal coats.
Thoughts???
Andrew
Hey Ben
We have plenty of the floor sealer we used on our floorboards,it was very good stuff at the time(commercial quality),Lindsay says he used some recently.That should be good shouldnt it????
Andrew
