1st November 2011, 10:49 AM
Engine breather- Puma
Had slight oil spray on under side of bonnet above oil filler cap and on rocker cover, removed filler cap and engine seemed to be pressurizing. I removed enging breather diaphragm and spring assembily about 1000km ago and oil on rocker cover and bonnet gone. Also slight leak on vac pump has stopped. There is no sign of exess oil in the breather pipe that goes to turbo, and the engine seems to be running a lot smoother. Has any one had similar? Was the breather assembily faulty (no sign of damage), or just another bullsh#t gadget. Might have been designed by the same engineers who think EGR is a good thing.
1st November 2011, 08:59 PM
Was the breather filter replaced at last service?
2nd November 2011, 10:35 AM
As far as I can see there is no filter, only a plastic/rubber diaphragm and spring assembly to isolate the engine from blow back from turbo. But as it is variable vane turbo I thought blow back would be negligable anyway.
2nd November 2011, 11:09 PM
#4
Freelander Td4 and L322 Td6 (same engine with two more cylinders) are variable vane and suffer badly if the breather filter is not replaced.
I will ask the oil people what they think..
3rd November 2011, 10:09 AM
#5
Cheers, any info is always good. But like I stated, there is no breather filter on the engine, only a direct line from rocker cover to turbo inlet with diaphragm to stop back pressure from entering engine, as far as I can tell.
3rd November 2011, 11:55 AM
#6
Just checked the workshop manual, only oil separator, no sign of any filter.
Allan
