Results 1 to 10 of 34
Thread: Swimming Pools
    May 2010
    Brisbane, QLD, Australia
    Swimming Pools
    Hi Everyone,
    I put a 50,000L pool in, just over a year ago. It's pebblecrete and has an automatic acid and liquid chlorine injection system.
    The system ran for months without incident...pretty fuss free.
    Over winter, I incrementally reduced the pump cycle time and was advised to observe the stability as I went. Got it down to 4 hrs and had no issues with water tests.
    By the end of winter a light brown mark started appearing on the pool floor. It apears that I have mustard algae....which I'm led to believe is an absolute bugger to get rid of.
    I upped the pump cycle back to 8 hrs, kept the chlorine levels really high, added numerous doses of algaecide and scrubbed the absolute bejabers out of the whole thing....over and over again.
    It's been weeks of high chlorine levels, and regular scrubbings......but to no avail. I've also cleaned the filter cartridges on three occasions.
    Ideas anybody? I'm seriously over it!
    Kev.
    sheerluck Guest
    Kev,
    That's not nice. I feel for you, as we had a major algae problem when we moved in to our place late last year (we ladled 3 wheelie bins full of algae out of the pool, it was seriously disgusting).
    What we were told to do to get rid of the last of it, was
    1. Brush like mad
    2. Vacuum the bottom of the pool to waste
    3. Dose weekly with algaecide
    4. Up the pH a little until the last of it was gone
    We also ended up replacing the sand filter. Once we did that, the water was crystal clear in a week, and has stayed that way since.
    Apr 2007
    Central Coast NSW
    We had dramas too - I'm a bit new to running a pool, so took a litre of water to the pool shop. I'm pretty sure I helped pay off the pool blokes ute, but the chemicals and crap he sold me got things back in order. It's been fine for the last two months....
    Ours is a salt/chlorine unit with a cartridge filter.
    I'd go to the pool shop mate, saves the headaches.
    Matt.
    Jun 2008
    Alstonville NSW
    Discovered that with a muck up with the timers our pool had been off most of the winter but came good with some shock treatment (s).
    Found this site Mustard Algae • Pool School • Trouble Free Pool
    Kev, haven't had mustard but I have had and still got black spot which is impossible to get rid of. The lesson I've learnt is it's better to over chlorinate (salt pool, via the cell level) and run the filter for a few extra hours then let things slide.
    .......and yes, pool shops are a rip off and you're better off working it out yourself.
    Jan 2010
    Victoria
    Hi Kev
    I have been building/maintaining pools for the last 13 years. Without seeing your problem it is hard to say what it is ie: metals staining, algae, steel penetration etc. If you like pm me and I will give you my number and should be able to help you out.
    As far as mustard algae goes the best way to get rid of it is to lower your ph and then bomb the pool with liquid chlorine. One thing to note and a common mistake alot of people/pool shops make is that chlorine is at its most effective when the ph is low. So if you ph is high (7.8 or above) and you tip in say 15ltrs of liquid chlorine (that has a ph value of 13) then the 15ltrs you have just tipped in will not be as effective at killing algae/bacteria as it would if your ph was say 7.2. (note all chlorine forms have a ph value, some low some high)
    Again pm me and I will be more than happy to help you out over the phone.
    Cheers Gavin
    Irymple, Victoria, Australia
    After reading the "Derusting by Electrolysis" thread, there is an option
    for you to make it into a large "Electrolysis Bath" for derusting items like chassis's, trailers etc.
    Cheers, Mick
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    South Yundreup,WA.
    You may have to do an acid treatment. That is what we do up here. Bring Chlorine levels down as low as possible. Usually 20 plus litres of acid, the filtration system must be blocked as does the chlorine dosing system. Pool shops usually have the gear for this. You usually leave it for a week maybe two and then scrub. Then set up the filtration system and filter, Then re adjust chlorine or salt levels.
    Good for black spot to or just a good clean up. Should be done once a year, usually in winter.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    "Then" or "than"? They mean entirely different things and, in this context, have significant ramifications.
    I note a lot of people (especially Americans) use "then" where they should use "than".
    Brisbane, Inner East.
    Pool, a hole in the ground into which you pour money. Been there, done that, never again.
    I have been looking at Sunshine Coast hinterland real estate for a while with the plan of relocating there. Land sharks ( so-called real estate persons) seem puzzled when I tell them that a pool automatically knocks $50,000 off my estimate of the property's worth. This is roughly what it will cost to remove the unwanted item and re-landscape the yard.
    URSUSMAJOR
