                                                14th November 2011, 06:59 PM
			Speed wobbles
					I have just finished a few jobs on the 90 including a new steering box (the old one had masses amounts of play in it).  I took the car out for test drive and it was getting the 'speed wobbles' where the streering wheel started shaking and only stopped when i slowed down.
 This happened a few times when I hit about 55kph +.
 I have been under and checked the steering system and there is nothing loose as far as i can tell.
 Any advice on where I should start looking?
 Thanks,
 David
                                                14th November 2011, 07:08 PM
					Did you rotate your wheels? They might be out of balance.
                                                14th November 2011, 09:02 PM
					Did you replace your Tie-rod ends by chance??  Check your Toe-in , or should I say Toe out . The Defender should have 0 to about -ve 2mm  toe in  or +2mm toe out .   1mm toe-in is enough to give your Def the wobbles !!
                                                15th November 2011, 07:41 AM
                                                #4
					Thanks guys,
 The wheels went back on the same side.  i think.
 The only part in the steering set up that i changed was the steering box itself.
 I will go over everything with the torque wrench again tonight just to be doubly certain i didnt miss something and check the toe in/out situation too.
                                                21st November 2011, 08:53 AM
                                                #5
					Turns out one of the bushes on the panhard rod had collapsed.  It was obvious when I pushed the body of the car from side to side.
 Took the rod into FWD motors in Brisbane and got new bushes put in both ends, supplied and fitted $11 for the pair!!
