Results 1 to 2 of 2
Thread: Got air bags in the rear? Need measurements from upper retainer
    Sep 2010
    Moe, Victoria
    Hi - hoping someone can help me.
    I'm looking for the inside and outside diameter of an RRC3352 as per .....
    I've tried to use this dodgy image from the web and made a copy of the ruler and moved it around, but it is just not clear enough.
    If you've replaced your rear helper springs on your 130 or 110 with HD suspension, then you may have removed your rear coil helper retainer (part no RRC3352) from the top of the helper spring and have the part lying around??? If so, would you mind measuring it for me?
    Alternatively I'd be grateful to borrow one just so I can use it as a template and will return it in exactly the condition I receive it. I'll meet any postage costs obviously (there is no chance anyone nearby will have one). This would be the best solution as I could then use it to test my fabricated plate.
    Thanks, Tim
    Jul 2011
    Yarrawonga, Vic
    ID = 84.3mm
    OD = 89.6mm
