Results 1 to 10 of 32
Thread: Question for a Kaymar bumper owner?;)
    Dec 2008
    Paris, France
    Hi,
    Looks like Ron is the only Kaymar bumper owner here IIRC.
    Do you know if the rear crossmember is a Kaymar thing or is it the same as land rover OEM?
    I bought a Kaymar bumper but i'd like that the guy that is 600km from me removes everything specific.
    Florent
    I'm not sure what you need to know, Flo.
    Can I phone you? (I have VoIP so the cost is minimal). If so, PM me with your no. and time to call.
    In the meantime, I have some pix here: http://p38arover.com/rover/p38a/kaymar/ and can add a lot more of the bar unassembled and also pics take from under the car after I fitted it.
    Dec 2008
    Paris, France
    In the meantime, I have some pix here: Index of /rover/p38a/kaymar and can add a lot more of the bar unassembled and also pics take from under the car after I fitted it.
    Ron, thanks for the offer but i found answer to my questions in your pix.
    Happy to see that it's possible to remove the arm and not carry the wheel if i do some Paris downtown trips with the tank
    Looks like really well engineered
    I think i'll have a longer arm made in order to center the wheel for look purpose only...
    Glad to hear the pix helped, Flo.
    Ron
    Dec 2008
    Paris, France
    Ron
    Hello Ron,
    Got my Kaymar. Any idea how to remove the swing away arm?. I can't pry the hub cap?
    Happy Christmas
    Flo
    The cap just pries off, Flo. It could be rusted on. Work around it with a large flat screwdriver. It might need a good pre-soak with WD40.
    After removal, there is a castellated nut with a split pin. Remove those and the carrier should lift off. The tapered roller bearings are just trailer axle wheel bearings and are commonly available here. They'll probably be rusty and either need replacement or cleaning and greasing. The shaft on which the arm swings is, I think, a trailer stub axle.
    Dec 2008
    Paris, France
    Thank you so much for those tips. I'll try it very soon.
    The thing is currently at my fabricator to see how to make some others.
    I'd suggest a stub axle on the other side as well - easy to do whilst it's off. Then you could make a LH or RH wheel carrier or something else to pivot one either side.
    Dec 2008
    Paris, France
    Hello Ron,
    I have a question about the steps 2 and 3 of the Kaymar mounting instructions
    I didn't understand anything about how securing the arms into the chassis rails.
    Chassis rails do have 19mm holes but it is not a pass through ie there's a hole on one side of the frame, and a hole on the other side but those are not matching
    Instructions refers to 2 rectangular spacer plates with 18mm holes.
    Of course, the old bumper wasn't provided with bolts so i need to order everything.
    Thanks for you help
    Flo
    Hi Flo,
    I didn't get any instructions with mine. I had to work it out.
    I'll get under it and work out what you need.
    Some of the nuts came with long pieces of wire welded to them so that they could be held up inside the chassis rails whilst a bolt was put through the hole.
    Can you scan the instructions and email them to me at p38arover@gmail.com ?
