I have been living in an owner built steel frame kit house for sixteen years. There were no problems with fittinjg door frames, window frames etc once you get your mindset from the "nail it" to the "screw it" attitude. Normal construction glues seem to stick to the steel especially if it is wiped with a turps soaked rag a bit before.
I can't really comment on putting a wooden floor onto joists, as I built on a slab. However, I can't imagine there would be any problems once you accept the use of screws rather than nails. (it would be possible to screw wooden battens to the rops of the joists if you feel the need to nail the boards) In this respect, I found that for attaching wood to the frame, the screws to use are ones designed for the purpose, with a drill point, then a smooth section greater than the thickness of the wood before the thread starts.
Apart from the kit supplier, we used a concreter, a plumber and an electrician, and did everything else ourselves (myself and my wife, with help from son, d-i-l, nephew etc).
Took about eighteen months from start to move-in.
I can see no drawbacks to the use of a steel frame, and several advantages compared to timber apart from the resistance to termites - dimensions are accurate, and do not change with weather. If building again I would not even consider anything else.
