How would the gas system know the pressure in the tank? There's no pressure sensor connected to the tank. Alarm is for low pressure in the rails.
Gas pressure is measured by the hose off the LH fuel rail. The hose from the LH rail goes to the gas system's MAP sensor, connection "P". Then there's the vacuum side of the MAP sensor, connection "V" to manifold vacuum. Then both 6mm hose connections from the converter are plumbed to manifold vacuum, via a tee piece or whatever.
