Results 1 to 10 of 11
Thread: Selectro FW Hubs
    Mar 2009
    Near Geelong, Vic.
    Selectro FW Hubs
    I'm at the stage of getting the hubs shipshape: brakes, seals & bearings.
    I have Selectro FW hubs fitted and a search of this forum for background resulted in my recalling the immortal words of Kamahl viz: "How can people be so unkind!"
    But, they seem to be working OK & I believe if it ain't broke you don't fix it.
    Can someone tell me how they are removed without having to dodge flying springs & ball bearings?
    They have 6 (SIX!) Phillips head screws holding the cover on. Seems like overkill! Is this a British thing? i.e. you can usually tell the nationality of an item by how it's attached. eg:
    British: 10 bolts
    American: 4 BIG bolts
    German: a metal clip
    Japanese: a plastic clip
    NSW far north coast
    Selectro are US made hubs.
    I had a set on one of my Jeeps a very long time ago (mid eighties), just can't recall how they came apart, but it was pretty easy. and they always worked, never had a problem with them but I always kept a set of standard drive flanges under the seat incase I broke a hub out bush.
    Dec 2009
    Queensland (though occasionally elsewhere)
    I had a set of Selectros like the ones in your pics. They sheared one day under light load on a greasy slope. Like Rick says - not a bad idea to keep some standard drive flanges up your sleeve. For me, I turfed the Selectros for standard flanges and would not change back...
    East-South-East Girt-By-Sea
    1.20 MB
    Removing Selectro hubs is easy. Take a 12oz ball pene hammer and smash up the hub. Then fit genuine Land Rover or HiTough drive flanges.
    The reason you use a hammer is so that they can't be refitted.
    Otherwise unscrew the phillips screws and be careful things don't spring everywhere. Then you can access the nut on the end of the axle and the six mounting bolts.
    BTW it's not that Selectro are bad per se, but IMHO FW hubs create more expensive problems than they create any savings.
    NSW far north coast
    [snip]
    Yes and no.
    We still have manual hubs on our GU Patrol and I use them, but we both occasionally (once a week or so) lock them to keep things lubricated, etc.
    I've seen a few front drive shaft splines flogged out and heard of a few diff pinion bearings brinelled on too many part time 4WD's from sitting in the one spot for too long.
    Having them unlocked does reduce a small % of driveline 'buzz' on the highway.
    Jan 2008
    Brisvegas
    And can be a godsend on a vehicle that already has 50 odd years of driveline wear.
    CC
    May 2009
    Austral, Sydney, NSW
    Quote Originally Posted by geodon View Post
    British: 10 bolts
    Just remove the inner 3 screws.. The outer ones hold in the cam. Putting them back is very time consuming.. Be careful. There's a manual for them on this forum somewhere..
    Wolf
    PS: I found a copy of the instructions on my PC.. Added it here..
    Attached Files Attached Files
    Last edited by Wolfman_TWP; 5th December 2011 at 10:44 AM. Reason: Added Instructions
    1972 - S3 LWB (109) Wagon - Parts
    1974 - S3 LWB (109) Wagon - Jess - (Registered)
    1975 - S3 LWB (109) Wagon - Parts
    1978 - S3 LWB (109) Wagon - Parts
    1979 - S3 SWB (88) Utility - Aurora (TBR)
    2014 - Defender (110) - Cher (MY15)
    1.20 MB
    Quote Originally Posted by Col.Coleman View Post
    CC
    CC I hear what you are saying, BUT: if you already have driveline wear, particularly in the prop shaft splines, having the FW hubs disengaged will finish off the prop shaft by wearing the remains of the splines in a single plane. At least a spinning prop shaft wears evenly everytime the front axle rides over a bump and the shaft compresses, a stationary shaft only wears the same points of the spline as the shaft compresses and extends with every bump and corner.
    Diana
    WA
    Diana
    I tend to agree. I have seen a number of cruisers and hiluxes over the years which have needed the front end rebuilt from lack of use. Some were surprisingly new.
    Mar 2009
    Near Geelong, Vic.
    Wolfman, absolutely magnificent!
    Thank you!
