Results 1 to 10 of 23
Thread: when a 300Tdi - runs dry of fuel - what then?
    Oct 2011
    sydney
    Just an idle post, bit bored. If I run out of fuel with a 300Tdi, am just wondering roughly how many cycles of the hand priming lever on the pump are generally required to get the system primed again and ready to go.
    Only other diesel I have had was a citroen xantia that had a priming bulb in the system and it took about 50 squeezes.
    Also while on this subject, roughly how low does the fuel gauge needle go before you run out?
    when fuel runs out, all the pumping in the world wont help if you havent re fueled the tank........only one way to find out how far the needle goes on your rig it so take it for a "test drive" Kramer style.
    btw, Ive never run out of fuel so never had to prime mine
    Oct 2011
    sydney
    Quote Originally Posted by uninformed View Post
    hmmm, i thought the refueling part is obvious enough to be assumed to have been done, in any case yes after i add fuel, is it easy enough to prime?, i have heard people relate the difficulty of priming this or that particular system,
    Jul 2007
    I ran out of fuel on the 300 tdi and after filling I just pumped it with the starter motor and it kicked soon enough. I rate that as easy.
    Torres Straits
    as has been written many a time on aulro. 300tdi self prime on the starter.
    Zero hand pumps required assuming your lift pump is in order.
    S
    NSW far north coast
    I've always primed by hand (lever is on the lift pump, crack the bleed on the filter and pump until a continuous stream) rather than cranking on the starter motor as I don't like the idea of running an IP dry, but many people have had problems with lift pump failure after manually stroking the lift pump, so take your pick.
    Aug 2009
    lota, brisbane
    it helps if you have a lever on the lift pump to do this and no matter how hard i look i can't find one on my 300TDi
    thats the only way i can do mine apart from putting an air line in the neck of the fuel tank and pushing the fuel forward carefully!
    NSW far north coast
    Quote Originally Posted by bigcarle View Post
    The OE one and the two aftermarket ones I have all have primer levers.
    Not saying yours doesn't have one, but it's unusual.
    Bloody hell, how often are you guys running out of fuel? I know I can't see my gauge at night, but damn.....
    Jan 2010
    tom price the pilbra, west aust
    Quote Originally Posted by slug_burner View Post
    same for my 300tdi never had to prime it, jst took about four turns on the starter and away she went.
