I suspect the answer is no can do, but is it possible to tow a disco many miles? I can't find anything in my documents/RAVE. I've never seen one with an A frame being towed behind an RV. I would think lubrication would be an issue.![]()
Yes you can, as far as you want, just stick the High/Low range lever into neutral, ignition to accessory and away you go, double check you can turn the steering wheel after putting too accessories though, just to be sure.
Baz.
Cheers Baz.
2007 BMW R1200GS
