Best guess is a wiring problem. The most common problems are poor earths, either at the tank or at the gauge, so these are what I would look for first (after checking the relevant fuse).
A test you can carry out is to disconnect the wire to the tank sender unit, and observe teh readings with it disconnected and shorted to earth. Readings of empty and full suggest the problem is at the tank, and this will be either a faulty earth or the sender unit. This can be removed from the tank (but not with it full!) and tested with a meter - I can't remember the resistance range it should have, but someone will come up with it. At this stage check that the float moves freely and is not punctured.
If the first test does not show on the gauge, change your focus to the instrument panel.
