Results 1 to 10 of 14
Thread: One Extreme Modification!
    Oct 2010
    Dixons Creek Victoria
    In an effort to keep this forum active due to the fact that there hasn't been a post in over 30 days,I want to describe how I recently performed the super extreme modification to my series Landy of replacing the plain single slot self tapping screws that attach my fuse box to the firewall with Philips head screws.
    Step 1. Remove plain screws by inserting the tip of a suitable plain screw driver into the head of the screw and turn in an anticlockwise direction until screw falls on the floor.
    Step 2, Install new, or used philips head screws of the same size and type thread by inserting the tip of a suitable philips head screw driver into the head of the screw and turn in a clockwise direction until you can turn no more, or strip the thread in the thin sheetmetal of the firewall, in which case you repeat both steps 1 and 2 with a little more finess and larger screws.
    Bill.
    Jan 2008
    Brisvegas
    Call that a modification. Still using the same old technology, with a different torqing device.
    I crunched the numbers, and run it past an engineer. After 6 months of letters and to-ing and fro-ing, he finally signed off on my cable tie. Sweet.
    Unfortuanately, now it is no longer elligible for Historic Rego
    CC
    cable tie,?, well aren't we all la-di-dah with newfangled technology. You sir are an affront to anoraks everywhere.
    You should have used fencing wire (if it needed to carry an earth) or baling twine (if you wanted it to insulate)
    look deep into your soul, you know that a true empirical restorationalist would have known that and done so.
    (and you could have kept your historic rego)
    Oct 2010
    Quote Originally Posted by Col.Coleman View Post
    CC
    Sorry if this is a bit too technical CC.but then again this is the Extreme Zone.
    but to requalify for historic reg, couldn't you simply replace the modern plastic cable tie with a bit of 25 year old tie wire?
    Bill.
    Jan 2008
    Brisvegas
    But I am getting a LH10 Mod Code for unlimited Street Rod Registration
    The extra power I get from the cable tie tuned to 28PSI, over forced induction fencing wire is phenonminal.
    A true Street Sleeper my 4 cyl buzz box. Blew the doors off a mobility scooter coming out of Wynnum Bowls club just yesterday.
    Smokin'
    CC
    Jul 2010
    pakenham
    Maybe if you had of installed a flux capacitor as well we could have called it extreme. It could have been the worlds first series Landrover flux driven time machine sent back 25 years for a strand of fencing wire
    May 2008
    Bundaberg Qld
    Smokin'
    CC
    and again CC --- Blue pills ??
    mike 90 RR Guest
    Quote Originally Posted by wagoo View Post
    Give it some Bling ... 316 SS ....
    I am sure there are one or two series Landys out there that could, but I have never seen one that would hit the requisite 88mph to achieve the feat.
    Quote Originally Posted by nicho View Post
    Blue pills?
    Quote Originally Posted by pop058 View Post
    Hi Paul
    I think he is talking about working with wire, not wanting to water.
    Or am I getting confused with go faster pills?
    Oh for a soft top 88" series one, I could practice my knots and my wire tie off's all day long!
