It is not difficult, but is likely to take a fair bit of time and effort. If you remove the headlining, you will see the roof is held on by a large number of bolts and nuts all the way round. Simply undo all of them and lift it off. While one can probably lift it, because of the size, you really need two to do so. You will also have to remove the windows on the curve of the roof before painting.
					 Removing the roof on 85 County
