Wow! Thats damn heavy for such a light camper!
Here is a pic of my camper.
It is easy to tow but has felt heavy at the front (not when towing) - certainly cannot lift it and it is not easy manoeuvre by hand. Tare weight is 680kg.
Today I put the jockey wheel on the bathroom and got quite a surprise - as I lowered the front onto the scales they just kept on going up and up and up - well past the scales 180kg limit - so ball weight has got to be in the order of 200kg or more. When weighing, the water tank (in front of the axle) was empty and van is unloaded.
Now given the layout of the van with the axle at the rear, ball weight is always going to be high but I was surprised by how great. I am tempted to move the water tank to behind the axle and remove the small 45A/h from the draw bar completely and install two 100Ah batteries on the rear bar in front of the jerry can holders.
While the ball weight is not an issue for any of my vehicles it does make the camper awkward to move by hand. I guess the issue is the design in the first place - having the water tank, fridge and kitchen in front of the axle was not a great move.
Any thoughts would be appreciated.
Your wife wasn't in the front bed by any chance?
Regards Philip A
Hey Garry,
might be an idea to take it down to the local weigh station and weigh it both with water and without and then you will know for sure what the actual ball weight is rather then guessing. Knowing what it is with the water tank full is more useful then when empty.
Personally I'd be checking with someone who knows their stuff whether or not adding so much weight to the rear is a good thing, even on such a lite camper.
cheer,
Terry
Terry
D1 V8 (Gone)D2a HSE V8 (Gone)D3 HSE TDV6 (Unfortunately Gone)D4 V8
No one has ever had any stability problems, but they have all had to upgrade their tow vehicle
That is quite a bit of ball weight, three times as much as expected before you put some water in the tank. I'd be placing few heavy things behind the axle.
The ball weight could have something to do with how far the axle is from the actual ball, unfortunately that's what makes it easy to tow, puting the water tank behind the axle won't do much for the ball weight empty, it will be alot heavier when full, so it is a good idea to move it.
To make it easy for moving it around, I'd suggest one of those ratchet jockey wheels, from all accounts they work really well.
Baz.
Cheers Baz.
2007 BMW R1200GS
Thanks Baz - I got one of them but went cheap and you get what you pay for. Mine is rated to 350kg but my camper bent it on its first move. Also the one I have has a ratchet (rat****) like a hi lift jack and the pins do not go into the holes - basically a heap of crap - will add some bracing and modify the rat**** and see how it goes - also the pump up tyre is not up to the weight and developed some cracks - so with these things it pays to look before you buy and not off ebay.
I think I will just put a bigger tank in the back and do away with the one in the front - there are no issues towing - just worried when offroad and have to man handle the van in tight situations - am going to carry a boat winch to help with that.
As with other comments I am very surprised at the towball weight for an approx 700 kg camper.
From very rough estimate from the photo, the distance from the axle to the hitch is approx x5 the distance from the axle to the rear. So a full 90L tank of water (+10kg for weight of tank for example) at the very back of the van will lighten the ball weight by 20Kg.
Similarly, 2x 100AH batteries weigh about 55kg total stowed in rear... may add about 10-11kg of "lift" at the front. 170 kg is still a lot of 'downforce' on a towball for that size van. AFAIK the towball weight should be ablout 10-15% of the GVM of the camper... 100 kg there abouts.... what's stashed inside the front of the van?
EDIT: Hmm on a "re-measure" the ratio might be about 3.5:1 instead of 5:1 in which case, on the above figures you might lighten it by 55kg...which leaves 145kg on the towball and is getting nearer the mark...
Looks like they put the fridge and door in , and then put the axle where it would fit.
Hmmm. A bit arse about if you ask me.
Regards Philip A
